Notices
Anybody got a cam bearing removal/install tool.....
Old 06-01-2010, 11:20 AM
cuda67bnl's Avatar
cuda67bnl
cuda67bnl is offline
The AZ puller has a collet that expands to the cam bearing. If the bearing did somehow break, there's not much chance of the rollers coming out. It's similar to this one from Harbor Freight. http://www.harborfreight.com/blind-h...ler-95987.html
Old 06-01-2010, 11:23 AM
soos's Avatar
soos
soos is offline
Originally Posted by petemac
I bought one from him last year, it's a very high quality tool. Now, where did mine go......
I know where it is. It's in Mayberry VT in the toolbox of a wannabe HD mechanic...
Old 06-01-2010, 11:27 AM
petemac's Avatar
petemac
petemac is offline
Oh yeah, that's where it is!
Old 06-01-2010, 01:31 PM
SDVmnt's Avatar
SDVmnt
SDVmnt is offline
Cool! Other than the bearing puller I thought there was one other tool that was needed? Or was that just a "nice to have" tool?
Old 06-01-2010, 01:44 PM
cuda67bnl's Avatar
cuda67bnl
No other special tools needed, just typical hand tools and a torque wrench.
Old 06-02-2010, 08:01 AM
iclick's Avatar
iclick
iclick is offline
Cuda67bnl is right, the bearing puller/installer is all you need. The service manual mentions two other tools, a sprocket locking tool and an alignment tool to insert the cams in the cam plate, but neither are necessary. They may speed-up and simplify the process, and if you do several cam jobs a week you would probably want them, but they aren't essential.
The locking tool only locks the outer cam-chain sprockets so you can torque the flange bolts, but all you need to do is have a helper hold the the rear brake while it's in gear. I honestly don't know why you need the alignment tool, as my cams went in the cam plate without the slightest effort.
I also have the Beatty tool and it is very good. Pulling and installing the inner-bearing was a breeze, and the tool is not expensive.
Old 06-02-2010, 08:08 AM
iclick's Avatar
iclick
iclick is offline
Originally Posted by hrchdog
The AZ one doesn't have an installer plus if the old bearing should happen to brake all the rollers wind up inside the motor, the one from mr. beatty has a capture sleeve to prevent this.
I've heard of this happening with blind-hole pullers, but not in a long time. I'm not sure how this could happen with these bearings since the needles are inside the housing and the puller would grip the housing.
For those of you who've installed bearings with the old cams, how do you know when the bearing is inserted the right depth? The Beatty tool seats it at the right depth automatically.
Old 06-02-2010, 08:21 AM
lionsm13's Avatar
lionsm13
lionsm13 is offline
Received 74,435 Likes on 22,407 Posts
Do you guys that have done cam changes with this tool have any tips that may be useful?
Old 06-02-2010, 08:38 AM
cuda67bnl's Avatar
cuda67bnl
If you do one at a time, you can easily look at the other to see where it sits.
SA66
Engine Mechanical Topics
02-06-2019 06:17 AM
fairlydangerous1
Gear and Other Items For Sale
01-16-2019 09:27 AM
racerdave
12-02-2014 08:54 PM
SmittyFXDL
05-08-2014 07:02 AM
Firechaser1141
11-30-2013 05:11 PM
Quick Reply: Anybody got a cam bearing removal/install tool.....
