Kuryakyn Wild Things 2G's....leanin' hard!
RE: Kuryakyn Wild Things 2G's....leanin' hard!
ORIGINAL: hoodz
hey enough talk,put them cams in there and pop a WHEELIE!
Once the snow flies and the salt is on the roads...........then I'll start taking things apart and having the work done. For now, I'll keep doing research, and start buying parts as I find deals on them.
Steve
ORIGINAL: hoodz
I think i'm gonna get wet on the way to work in the morning.what do you think?
Break down and take the car...........give the bike the day off.
Steve
ORIGINAL: maineultraclassic
None of the Andrews cams match the Wild Things cams specs. I would highly doubt that Andrews would copy the Wild Things cams under their own name.......contracts and stuff like that.
The TC-2G and the HQ-0034G have very similar specs..........I just wish I knew better what all the specs meant when it comes to the power potential and location of the powerband.
Steve
Steve
What you can do to compare cam measurement values is to use the HD Screamin' Eagle book.......look at their 203, 204, 211, 256, etc. and note the duration and lift values and the application notes. Then, compare the duration and lift values of those HD cams to the others, whether it is an Andrews, Crane, Kuryakyn, S&S, etc.
Log on to the Andrews website and you can see their description of where each cam makes the best power in the rpm range......it would be a good start for you. I didn't know much about gear drive until I did a search on this forum.....and researched the subject pretty hard.
