How to remove left side grip?
Old 10-09-2010, 05:15 AM
sparky_mo's Avatar
sparky_mo
sparky_mo is offline
Originally Posted by buzzy62
i also plan on putting on these type of grips but instead of glue that comes with it i'm going to use grip tape that you would use on a golf grip, water activated kind. 1 wide spiral wrap should do it.
+1 on the double stick golf tape. easy on. no mess. easy off. where do you get the water activated kind? I've either went with a solvent you can get that's used for putting on golf club grips or lighter fluid.
  #42
Old 10-09-2010, 06:52 AM
BigDaddyMike's Avatar
BigDaddyMike
BigDaddyMike is offline
Make sure bike is secure on jiffy stand. Grab the grip with BOTH hands. Twist it one way and hold form for a few seconds, then quickly, with all your might, jerk it back the opposite direction. Do this a few times if it doesnt break the first time, it WILL come loose.
  #43
Old 12-03-2010, 01:50 PM
masterblaster's Avatar
masterblaster
masterblaster is offline
Thanks guys ,saved me $50
  #44
Old 12-03-2010, 02:04 PM
slothy's Avatar
slothy
slothy is offline
my 2011SG stock grip was glued..
  #45
Old 12-03-2010, 05:32 PM
2011FLHTK's Avatar
2011FLHTK
2011FLHTK is offline
Use lighter fluid. It will soften the glue.
  #46
Old 12-03-2010, 08:00 PM
bmcgc's Avatar
bmcgc
bmcgc is offline
I didnt read all the posts.
I take a very small diameter screwdriver and work it down the grip then work the nozzel from a can of WD40 in. Give it some good squirts, leave the nozzel in and start working it back and forth, it will come off.
If you need glue on a reinstall use a small amount of gorrilla glue, its mositure activated. Use a little, it will hold but will twist off pretty easy if you ever want to remove it.
  #47
Old 12-03-2010, 08:23 PM
Bobzilla's Avatar
Bobzilla
Bobzilla is offline
Originally Posted by glide2005
+1 on compressed air or utility knife.
++3 on the air works well
  #48
Old 12-03-2010, 08:36 PM
Blackheat's Avatar
Blackheat
Blackheat is offline
Since you have been twisting and turning and jerking and nothing. It's time to bite the bullet and cut and buy new ones. You don't want to throw your back for a few bucks and how much more time do you want to keep waisting on the grips anyway.
  #49
Old 12-04-2010, 08:01 AM
cogener8's Avatar
cogener8
cogener8 is offline
07 RKC and stock grips were glued.
  #50
Old 12-04-2010, 02:55 PM
badjustbad's Avatar
badjustbad
badjustbad is offline
Take a piece of stiff wire (coat hanger) and bend it into a Z shape. Slide one end of the wire as far as you can under the grip the crank on the other "handle" end like an organ grinder. The wire will walk around the grip separating the grip from the bars.
Quick Reply: How to remove left side grip?
