VOX vs PTT
If I remember correctly from my UC days, there is two settings for the intercom. One is for the sensitivity of the VOX, how easily the intercom will open, the other is the volume, how loud the voice is inside the helmet.
You should be able to access these settings on the face of the radio.
If you use the PTT button, be advised that any conversation you have may be transmitted over the CB radio and anyone on channel will hear you.
I liked the VOX setup a lot, when set correctly it works great, unlike the intercom on the Gold Wings, they sux, stay open all the time. They are so bad a fellow rider invented Mic Mutes to turn them off and on...and sold like hotcakes...
Are you using the foam covers? and do you have the mic part facing you and not the air? Believe me I've seen a lot of them facing the wrong way and it's easy to get them turned around...
Once you have it set, it'll be sweet.
Thanks for the suggestions.....However, once you turn on the intercom it defaults to VOX. What I want to know is how to disable the VOX be able to talk to my passenger simply using PTT. The owners manual says all you do is plug in the headsets and use the PTT button. I tried to do it this way and it doesn't work ?
Thanks
Thanks
Thanks
I don't believe you can talk to your passenger via the CB without broadcasting over the CB....you gonna have to use the intercom and that will engage the VOX....stay with it, you'll figure it out.
If you have the settings set low, you will have to break the vox with a "um" or something like that, if you're going slow or not in heavy traffic, move the setting up so the "um" is not needed...easy once you get used to it.
Yes it will default to VOX, but that's were the settings come into play, you'll have to play with it and get it set right.
Thanks for all your help, but I've played with the settings for weeks and I'm tired of having to adjust the VOX depending on wind, semis, my jackpot mufflers, etc. Just when I think I have it set right...... Anyway,
The manual does a crappy job of explaining how to set the intercom to use PTT only. It tells you that you can do it, and warns you that if you have the CB turned on you'll be transmitting what you say over the CB but it doesn't really tell you how to use the PTT with the intercom. I read it several times.
Anyway, I went out before and finally figured it out. You turn on the INT and adjust the VOX sensitivity all the way down. The screen will then read VOX closed. Once it's closed you then use the PTT button to talk over the intercom which is seperate from the CB radio. I was trying to get it to work with the INT turned off because the manual talks about PTT and that all you do is push the button on one page and tells you that you can do it that way and then on the next page refers to the VOX and turning on the INT to adjust all the VOX settings.
For me, this is the way to go. I don't want to have to keep playing with the sensitivity and have the VOX mic on when I really only say a sentance or two every hour anyway. If I'm on a group ride and we're using the CB I'll have to revert back to the VOX settings.
Thanks for all the help and hopefully everyone else knows now how to set it up like this to talk by just using the PTT button.
if i remember correctly, you can disengage the vox by turning it down. the ptt switch will not transmit across the cb unless it is also on. you should be able to adjust the vox...i think its one of the buttons on the face plate of the radio. like mentioned earler, stay with it, you'll figure it out. thats what i had to do.
cass
cass
