Changing clutch cable
Old 05-27-2010, 09:25 AM
PistonPuller's Avatar
PistonPuller
PistonPuller is offline
Yes it works. If you already have the blocks then its worth it. No need to change out the oil if you don't have to. Also since you have an 09, you wont have any issues with the exhaust. just need to loosen the heat shields. The older bike required the removal of the exhaust
Old 05-27-2010, 03:51 PM
Glide'n09's Avatar
Glide'n09
Glide'n09 is offline
Originally Posted by Jags93
Haven't done the swap yet but I cut down the short side of a 3/16" Allen wrench to fit on the lower bolt with the exhaust in place. I'm hoping to get the clutch cover off with only having to remove the heat shield, and not the exhaust itself.
Tried that, won't work. It will get the bolt started out but when it gets out so far you will back into your pipe. Ended up having to use ball end t-handle allens on mine. Had to be very careful not to muff up the heads on the bolts..
Old 05-27-2010, 04:06 PM
Jags93's Avatar
Jags93
Jags93 is offline
I figured at some point I would have to grab the head of the bolt with my fingers or pliers.
Old 05-27-2010, 04:09 PM
shagnasty's Avatar
shagnasty
shagnasty is offline
Drain the tranny, it's a good time to put in some fresh shockproof heavy!
Old 05-27-2010, 04:16 PM
BigMike's Avatar
BigMike
BigMike is offline
Received 1,579 Likes on 680 Posts
Only if you have the factory headers. No need to remove the exhaust if you have true duals.
RickK
10-03-2018 06:07 AM
lateralus
08-22-2012 10:20 PM
skirtbum
06-26-2010 05:45 PM
crewzerdude
04-27-2010 09:18 AM
rrsjs5
09-24-2008 03:03 PM
Quick Reply: Changing clutch cable
