My 07 SG, with SE heavy breather, stage 1, injection mapping, big radius 2-into-2 Vance and Hines, has an intermittent stall when I come to a stop during rides and shift into neutral. Sometimes just depressed rpm, other times all out stall. Anyone else have this problem? 12k miles. Thanks!
Mine was trying to stall out at stop signs. Pull the air cleaner and clean out the IAC just inside the throttle body on the left upper side.
Do this by squirting a cleaner into the hole while cycling the valve. Ignition on, flip kill switch on and off. Mine was pretty dirty.
You may also find your air cleaner a little dirtier than what you may think.
I have a 06 Street Glide - carburated with a stalling problem. I have gone through the carburated and it is fallling off and stalling. Any ideas?
Thanks!
