Nostalgic Air Cleaner cover broken
Anyone have the center of the air cleaner break out? Mine was mounted on the SE air cleaner and lasted a couple thousand miles and just fell off while riding down the highway. I have seen a thread refering to a rubber gasket or washer needed to keep down the vibration, but mine didn't come with one. Did I have misisng parts? I have had it on the bike for more than the 90 day warranty from HD. Any suggestions?
The Gasket is required to keep the Cover from resting on the backing plate. It also prevents the cover from rotating. You probably waaaay over torqued it too.
Did the screw pull through the filter or the cover? Either way, you'll be buying one or the other.
I made my own gasket out of 1/2" rubber. Also bought a longer chrome screw.
