Oil blowing out of my intake.?
I have just under 10000 miles and I took a little 200 mile mission yesterday. I Was running pretty hard most of the trip when I got home I had oil on my right bag and it was dripping out of my Stage 1 air cleaner. I have had the current mods on there for some time. I havent change my oil in a months and this has never happened. Only thing different is the PC autotune. I'm going to clean my air filter today what else should I look at? I am planning on doing my Cams next month but need to figure this out before I order any more parts.
This is a common occurrence and really nothing to be too worried about. It could be from several sources. Blocked engine or head venting, too much oil even an oil pump alignment. Since you are at 10,000 miles, change the oil and leave it 1/2 qt low. This is the most common cure. Since you are going to clean your AC, check the head vents and when you change cams make sure your oil pump in aligned properly and be sure to use new o-rings.
Went to clean my filter after work today...... 2 out of the 3 standoffs were broken in the throttle body and they actually pulled through the K&N filter mount. I am also missing the rubber o ring on the front side breather tube. I have no idea how this could have happened unless it was hit or something. there are no signs of physical impact. I'm at a loss. I need to get the standoffs out so I can replace them. At least I know where the oil was coming from
