SG air shocks? Won't maintain pressure?
The rear shocks on my 08 FLHX don't hold the air pressure. What pressure are you running 2 up? every couple of days I seem to be losing all pressure, I put more air in and two or three days later I check and have 2 pounds or less. What's going on, air leaks? Fittings, valve, shocks? How do I determine where the problem is? Anyone?
What are you using to fill it with? Hopefully NOT the same gas station air hose you fill your car tires with. The owner's manual instructs that the pressure is too high and will damage your lines causing leaks. It also tells you to use their very-low pressure hand pump to add air to the air suspension. There are also charts in the owner's manual suggesting recommended air pressures depending on your riding situation (one-up, two-up, different weights...).
I had the same issue on my 09 RK
Don't fret. Use some soapy water around the lines where they go into the valves. The leak is probably at a coupling. Check your owners manual on the air lines. The couplings are just press fits and can be fixed easily. When you pull the hose out, just trim the end piece and put it back in and pull the black ring tab out a little to 'seat' the hose. My shocks have held 25lbs for over the entire spring now.
Gas Shocks
What if someone filled the air shocks and damaged the "bladder"? Are the shocks now ruined? And does that "line" run to the front of the bike also and what does it do there. How can I check if the leak is up front? Thanks, Dennis. Additionally is it better just replace with gas shocks?
