Notices
SE204 cams in a 103
Old 05-23-2010, 12:21 AM
FYRKNG's Avatar
FYRKNG
FYRKNG is offline
6th Gear
I think my fingers got ahead of my brain. I believe I ended up with 9.5:1 compression, but I'll have to see if I can find the paperwork for my head porting. He told me over the phone the chamber volume and I wrote it down, if I can find it, but I'm almost certain it calculated to 9.5:1 with my pistons, head gaskets and chamber volume. Either way, it runs well on premium 91, ethenol blend 89, or 87 regular depending on what I can find. It does however, prefer premium, and delivers best fuel economy and probably a bit better performance using premium.
Old 05-23-2010, 07:37 AM
troop's Avatar
troop
troop is offline
I have read that the 204's can be a little finnicky with compression. I believe the police bike 103's have the same pistons as the 103 Ultra and they're a tad less compression than the 103" SE flat tops. I'm playing it safe and going with stock head gaskets. According to the Big Boyz calculator at my altitude I'll be at 9.85 static and 9.29 corrected. Should be safe with most varieties of premium gas...
Old 05-23-2010, 02:44 PM
Mike's Avatar
Mike
Mike is offline
Yeah, troop, that's what I figured as well. I can tell you the bike seems to run just fine on 91 octane. No sign of predetonation yet, and that's with the timing straight up. I haven't gotten cute with the bike yet, but it sure feels strong. The power is right there when you roll on the throttle, no waiting for the cam to spool up.
I went ahead and changed lifters and put in the baisley spring while I was in there. Running straight 50w dino oil, and the valve train is quieter than it was prior to the change.
I'm sure there's lots of cams that make more power than these do, but I really like the way these ride.
junglejoe
Engine Mechanical Topics
11
12-29-2015 02:35 PM
Tn.Heritage
06-15-2010 11:50 PM
dyna081
02-27-2010 04:36 AM
Vinsil
01-14-2010 12:04 AM
louddmax
Exhaust System Topics
10-14-2008 04:02 PM
Quick Reply: SE204 cams in a 103
