I have an 04 flht. I installed a new cruise control and now it won't start!
I do not have spark. Also the right blinker doesn't work either.
Anyone got a clue what may be wrong? Thanks
Probably pinched wire(s) in the right hand switch housing you installed--easy to do. Open and/or remove the housing from the handlebar and see if the bike will start and the right turn signal work--opening the housing may remove the short(s) from pinched wires at the handlebar where the wires exit the housing, and aid in diagnosing the problem.
Thanks, I appreciate your help. Ok, I took the throttle apart and there are no wires pinched. I tested the turn signal while assembly was off and still doesnt work. Any other suggestions?
