Swapping head unit..disconnect battery or just the maxi-fuse
05-21-2010, 02:40 PM
Swapping out HK head unit with an aftermarket unit....should i disconnect the battery or just pull the maxi-fuse.
Thx
05-21-2010, 03:11 PM
The Maxi fuse is enough. All power going to the fairing area is fed thru the maxi fuse.
05-21-2010, 03:14 PM
You can never go wrong by disconnecting the battery.
05-21-2010, 03:15 PM
05-21-2010, 04:25 PM
Originally Posted by
Maimas
+1
What's so difficult about disconnecting the battery? an extra 10 mins could save you a whole heap of trouble.
J McBri
05-13-2019 09:13 AM
Mchad
11-23-2015 06:02 PM
deadman77
08-11-2013 07:48 PM
Dragan
08-17-2009 07:14 PM
db2753
06-20-2009 08:07 AM
09,
2009,
battery,
disconnect,
disconnecting,
flhtcu,
fuse,
glide,
head,
install,
maxi,
maxifuse,
radio,
street,
unit,
unplugging
