Front Brakes...
Front Brakes...
Are the HD front brakes supposed to suck? My RKC front brakes dont do their job too well I feel. How should they be? I am used to riding a Buell XBR and rice rockets where I could stop on a dime with my front brakes. I can hit my RKC hard and not do much. Is it my rotors? My pads look good and seem to have a lot of life left.. Help please. Thanks.
Yeah, they are not the best stoppers in the world even though they are made by Brembo, and even with the ABS option. Unlike my other bikes, I have found my 09 RK is a front and rear brake kind of bike when you want to slow down, and even then it's best to leave plenty of room.
Love my beast, but it doesn't stop like my other bikes.
The pistons in the brake calipers do not have dust boots on them. Bad design. The brake dust builds up on the pistons and causes them not to retract fully and makes the brakes feel very mushy. Here is a link on how to go about cleaning them.
http://www.lyndallracingbrakes.com/service_tech.htm
I did mine a while ago and the difference is amazing.
Try Brembos
Looking at your signature pic, I'm thinking you have a 2003 that came with the same crappy brakes my 2004 came with. In 2008 H-D went to a new design Brembo brake set that is much improved over the older brakes (like ours).
If you're really into it, you can buy a complete (slightly used) 2008-2010 H-D Brembo front brake kit on eBay for about $350, calipers, rotors, master cylinder, and matching clutch lever. the new rotors are larger, but bolt right onto the old front wheel. The new calipers fit the new larger rotors and also bolt right onto the old fork. The new master cylinder is a bit larger, to move more fluid, and also bolts right on. I have a complete set sitting in my living room waiting to be installed on my 2004 RK.
There are lots of good posts on this retrofit/upgrade, like this post: https://www.hdforums.com/forum/touri...d-at-last.html
JR
JR
Yes but he is right, they don't retract enough and I had to clean pistons about every 2500 miles. I haven't seen the problem as bad with the brembos.
Beary
