I have read the manual and unless I missed it, I can't figure out how to have the CB on without having the radio music playing. I just want to try and use the CB with out anything else in the background.
The music radio volume can be turned down to mute. The CB volume level can be set while the display is on CB mode or while receiving a CB transmission. The music and CB volumes are independent of each other.
thanks guys!! I was just in the mindset that the radio volume and the CB volume were one in the same, and not independant of each other as was just pointed out.
OK, I guess that was my dumb question for the month
A quick way to get volume adjustment for the CB is to push the squelch button. This will temporarily put the radio system in CB mode and the CB volume can then be adjusted separately from the AM/FM volume. Otherwise, select COM from the radio front panel. In the first case the system will automatically revert to what ever it was set to before the squelch button was pushed. In the second case, the system stays in COM mode. In both cases, the CB volume can be adjusted separately from the AM/FM volume.
