On the road tire plug kits
Old 05-19-2010 | 02:18 PM
hydrolock43's Avatar
hydrolock43
Default On the road tire plug kits
Do many of you carry a plug kit for you tubless tires? I see that there are a few available that use co2 cartridges or an electric pump or a hose off the cylinder to pump the tire up. I figured in a bind this could get you home. Any one know of a good one?
Old 05-19-2010 | 04:08 PM
slhanks4's Avatar
slhanks4
I do. I bought it at Cycle Gear, it has plugs, patches and a couple of small canisters of compressed air. I also carry a small Slime 12v compressor.
Old 05-19-2010 | 04:47 PM
truckerdave's Avatar
truckerdave
senior experienced all-knowing leader of the unwise
I carry a repair/plug kit and the slime 12 volt compressor in a saddlebag. Compressor plugs into lighter socket. Think i got them at wal-mart or autozone.
Old 05-19-2010 | 04:50 PM
nskitts's Avatar
nskitts
Everybody swears by the Slime pump ran off your battery. You can get them cheap enough at several different places. Those CO2 canisters are a one try deal so if you don't get if plugged right the game is over. The "engineair" pumps that hook up to one of your cylinders are not generally ragarded that highly although I don't know why.
Old 05-19-2010 | 04:53 PM
hydrolock43
Default What about using the spark plug hole
Rather than carrying the compressor or co2 cartridges why not use the bike engine for compressed air?
Old 05-19-2010 | 04:58 PM
WI Bob's Avatar
WI Bob
Heck, why not? The MoCo seems to think that back cylinder is not needed all the time anyway. ;-)
Old 05-19-2010 | 05:05 PM
xxxflhrci's Avatar
xxxflhrci
I carry regular sticky tire plugs from Walmart and the guts out of a cheapo 12v compressor...Yes, I have used the plugs more than once with no problems.
Old 05-19-2010 | 05:30 PM
vzts4q's Avatar
vzts4q
I use a Stop & Go plug kit.
http://www.stopngo.com/motorcycle.asp#inflationdevices
I also went with the expensive CyclePump inflator.
http://www.bestrestproducts.com/p-29...ure-model.aspx
There are kits available at both sites that include a pump and plugs.
Old 05-19-2010 | 08:17 PM
dougbk's Avatar
dougbk
I carry the stop and go kit, but have never used, because both tires that I have lost have been blow outs.
Old 05-19-2010 | 11:09 PM
MikeDCop's Avatar
MikeDCop
I carry a simple plug kit and a small compressor that I got at Wal*Mart
