Thunderheader mufflers
RE: Thunderheader mufflers
If your runnung true-duals you need two thunderheader muffs for them.Thats what i'm running.The falsy is for the 2into 1 with a cross-over pipe.Also by the shields from J&P cycles for 50.00 bucs!
If you have an SE aircleaner or ness big sucker,you'll need a PC III or some other device to tune it because V&H fuel pack dont dont have maps for other brands of pipes and muffs.(dyno guy can possibly tweak it to work,i'm not sure)
If you havent changed the air/cleaner you probably be ok with out,but a dyno tune will definitely maximize the performance!
FenderGuy53
08-24-2011 02:44 PM
