Speed at which I shift with 6 speed
Old 05-18-2010 | 04:16 AM
Swamphunter's Avatar
Swamphunter
Default Speed at which I shift with 6 speed
The one thing I am having trouble with getting used to with the Road King over the Dyna pictured below, is the speeds at which I shift in to a higher gear. It seems that the 6 speed needs to be shifted at speeds that the dyna was running comfortably in, if that makes any sense. I realize its because of the extra gear, but it seems like at 55-60mph it falls in between 5th and 6th, when the Dyna ran strong in 5th. Will I get used to this difference? Not sure if I am making myself clear or not.... been up all night with a bad cough and cold ... lol
Old 05-18-2010 | 05:52 AM
Bam Bam's Avatar
Bam Bam
I'm runnning a 2010 RKC and also feel I need to be above 60 mph for 6th. Anything less and 5th seems to be comfortable for the bike.
Old 05-18-2010 | 05:57 AM
Overdoo's Avatar
Overdoo
Default 6 speed
I think you'll find that the lug point on that Dyna is about 2k. The newer bikes with the stock 96's are at 2500. I have an 08 SG. I watch my tach and don't shift into 6th till I am crusiing at 2500 or above on the highway. For me that's about 65-66 mph. As long as I stay above my lug point my gas mileage is in the mid 40's and the bike runs great. You'll get used to it. Take care of that cold!!!!!!!Hope that helps.
Old 05-18-2010 | 07:05 AM
sh57's Avatar
sh57
I try to stay out of sixth gear untill about 65, it is easy to mess around and lug your bike while in 6th.
Old 05-18-2010 | 07:43 AM
navyman's Avatar
navyman
I don't use 6th below 70 mph.
Old 05-18-2010 | 07:44 AM
todd-67's Avatar
todd-67
65-70 for 6th here.
Old 05-18-2010 | 07:47 AM
1931jamesw's Avatar
1931jamesw
Put in SE-255 cams. Problem solved.
Old 05-18-2010 | 07:51 AM
cuzkee's Avatar
cuzkee
I leave 5th when tach hits 3-3500. My 2010 SG with 103 Stage III kit needs to be kept between 2500 and 3500 rpm to feel good at cruising speeds.
Old 05-18-2010 | 08:04 AM
harley-jones's Avatar
harley-jones
What he said! I can run in 6th gear at 50 to 55mph up and down the hills at 2000rpm's without lugging the engine.
Before the cam change I had to be about 60 to 65mph.
08 SG
Stage 1
Reinhart TD
255 cams
SE race tuner
Old 05-18-2010 | 08:13 AM
shortride's Avatar
shortride
65 mph is a comfortable speed in 6th gear, as long as it's flat terain.
Quick Reply: Speed at which I shift with 6 speed
