New stereo and arc amp shuts off
Old 05-17-2010 | 11:42 PM
zippo2's Avatar
zippo2
Default New stereo and arc amp shuts off
Just installed a new pioneer P4200ub stereo w/ the hawg wired install kit which was easy and a perfect fit, and a arc 2 channel amp, running two 6.5 focals in the fairing and two 6.5 kenwoods in the lower fairing. Sounds awesome but after about 45 minutes of cranking the tunes it shuts down so I turn it off a minute and start it up again. So my question is can the amp be over worked and overheating or what? Any feed back.
Old 05-18-2010 | 05:24 AM
xtremechopper's Avatar
xtremechopper
Sounds like that is exactly what is going on. What ohm are the speakers you are running? If they are both 2ohm then that is too much load on the system. Also, check your gains, if they are too high this will also do this.
Old 05-18-2010 | 07:15 AM
1flhtk4me's Avatar
1flhtk4me
Mine does the same thing.I'm running the stock head unit with the ARC amp,2 ARC 6.5's and 2 5.25's 4 ohm speakers.
I talked to fire cap last year about this..He said to look at the lights on the amp when this happens.They will blink for a code reading.
Thought I had a bad speaker(replaced) but still does it.
Have not got back to him or called ARC.
Old 05-18-2010 | 02:18 PM
zippo2's Avatar
zippo2
I want to say Focals in the fairing are 4 ohm and kenwoods in lower leg fairings are 3 or 3.5 ohm, I know that sounds odd, I'll have to check it out. Thanks for the reply I'll adjust the gains back a bit, I had them set at about 3:00 on the arc amp, maybe I should call arc themselves to see what they say. Or wonder if an arc 4 channel amp would fit and do a better job running 4 speakers. Thanks
Old 05-18-2010 | 02:33 PM
cap5369's Avatar
cap5369
Have you tried changing the Gain on the amp? Turn both adjustments up till
the indicator is just past vertical and pointing between the “A” & “I” on the writing on the word “Gain” above the top dial. Once Wayne told me about the new setting mine don't shut turn off. I was running the stero wide open alos he told me to keep it about 2 bars from wide open on sound. Hope this helps
Old 05-18-2010 | 02:47 PM
zippo2's Avatar
zippo2
Thanks cap5369 on the reply I'll adjust the gains back to that setting and try that. Yes Wayne's a good man has helped me a number of times. Would it help to run the fairing speakers off the amp and the lower speakers off the deck? Or would the sound be way off?
Old 05-18-2010 | 02:52 PM
dan11809's Avatar
dan11809
The four channel will perform better,but it's a tight fit.You'll have a hard time getting the fairing back on,but you can do it.
Old 05-18-2010 | 03:21 PM
TRMRC's Avatar
TRMRC
I tried this setting too, but didn't feel it was much more than the stock volume. I have 4 ohm 6.5" Speakers in the fairing that can handle 90W RMS each. . I run into the issue with the HIGHS cutting out for a few seconds when I have the gain up too high. I just think between the A & I is low..but yeah it keeps the amp from shutting down
Im puzzled too
Old 05-18-2010 | 03:23 PM
zippo2's Avatar
zippo2
Has anyone installed the arc 4 channel amp 125.4 under the fairing w/ an aftermarket deck since they are a little smaller than the stock deck
Old 05-18-2010 | 03:36 PM
Harleypingman's Avatar
Harleypingman
If you have already talked to Wayne (Firecap501) you have probably talked about how to wire four speakers to a two-channel amp. For those who haven't, this explanation was helpful explaining speaker impedance and series/parallel wiring:
http://www.bcae1.com/spkrmlti.htm
As for the ARC 4-channel amp, it's unlikely that it can be installed in an EG or SG without significant modification to the vertical (black) fairing brackets to accommodate the wiring connections to the amp. On an RG, the amp can be installed between the glove box and inner fairing.
If you want a 4-channel in-fairing amp on an EG or SG, take a look at the new Hogtunes 4-channel amp. It's 40W X 4 (160 watt).
Quick Reply: New stereo and arc amp shuts off
