LED Tri-bar run/brake light
much brighter than stock and 1 stick fits in very easily. I used the one with the flasher built in to get some extra attention.
http://www.customdynamics.com/knight..._light_bar.htm
* 2 bolts and the electrical plug and the unit comes off the bike.
* Use a hair dryer or heat gun and slowly work the lens off the unit
* Remove old board, use dremmel tool or file to remove existing tabs
* I glued tin foil into the housing as a reflector
* Double sided tape the Knight Riderz and rewire
* Close up unit and reinstall
I've got photo's somewhere from when I did this, if your interested I can post them.
[QUOTE=Chicago 03 King;6736301]Check out the Custom Dynamics "Knight Riderz" 12 led bar
I was going to try this....http://www.radiantz.com/cart/index1.html?c34.html&1
Does not have the flash function and a little more expensive but it has 55 leds....
was planning on just adding to the back of the housing (facing the lens) and just splicing the wires to the existing wires...just need to get it a part and measure to see if it will fit.
Winter project....
Winter project....
Sportrider79
04-15-2012 09:50 PM
