PCV from Fuel/MoTo, Question?
Installing my PCV, and in the process of installing the switch to toggle
between the 2 MAPS.
My question is, WHICH MAP AM I USING BEFORE I CLOSE THE SWITCH?
My thinking is F-Moto, would have the COOLING map in the open position.
And the MPG map in the close position!.What say you......... Tenn.Vol.
between the 2 MAPS.
Jamie (at Fuelmoto) told me that Position 1 is in use when the switch is in the open position and Pos. 2 is in use in the closed pos.
To find out which map is installed in which position, follow Mopar400's advice.
If you're still confused, call Fuelmoto and they will be able to help you out.
It isn't nutty at all. Some PCV owners are fine with one map, but using the switch allows you to maximize mileage yet be able to switch to a richer map in the cruise range for better cooling when needed. You can't have both at the same time, although there are comprises in between.
