amp and speakers for retroradio
Old 05-17-2010, 09:33 AM
dunnp650's Avatar
dunnp650
dunnp650 is offline
Default amp and speakers for retroradio
I have done a search and am confused I put a biktronics retroradio in mt 07 standard and it has I beleave has 4 ohm???? what amp and speaker upgrade can be put with this set up or will any one of the jm or hog tune ones work I am looking for a plug and play unit thanks in advance for any >>
Old 05-17-2010, 09:48 AM
niteglide's Avatar
niteglide
niteglide is offline
I think the J&M and Hogtune speakers are 2 ohm. Any aftermarket 5.25" 4 ohm speakers will work with your setup. I have the retro radio in my 07 standard also. Im using a Sony head unit with Memphis Audio speakers.
Old 05-17-2010, 11:09 AM
Harleypingman's Avatar
Harleypingman
Harleypingman is offline
Contact the amp vendors and ask them about your application. The amp will typically use the speaker outputs from your radio for its input signal and you'll need speakers that are compatible with the amp's output impedance. The amp's specs will tell you what impedance speakers to use; some are stable at 2 ohm and will also use 4 ohm impedance speakers. But, ask the amp vendors for their recommendations.
Old 05-17-2010, 04:39 PM
Max96's Avatar
Max96
Max96 is offline
I have the same kit installed. Blew out the Hogtunes speakers and replaced with a set of regular Kenwood 3-way car (4-ohm) speakers. They have been in there 2 years now and still sound great.
Old 05-17-2010, 05:18 PM
BillyG0856's Avatar
BillyG0856
BillyG0856 is offline
When I bought my retro-radio from Biketronics, I ordered the speakers directly from Pez @ Hogtunes. I believe they were the 914 speakers. If I recollect, he told me that with this setup, the Sony 630UI, I'd have to use/order from the 1998-2005 series.
As of yet, I've had no problems out of either the Sony unit, the Hogtunes, or the Hog Pod tweeters. I plan to order the rear speakers from Hogtunes soon.
Hope this helps...
Billy G
gja
Audio Systems
07-18-2015 07:41 AM
twistr
Audio Systems
11-19-2012 05:30 PM
mca1989
05-15-2010 10:51 PM
woosh
08-05-2009 07:25 AM
Badbagger
02-10-2008 11:18 AM
Quick Reply: amp and speakers for retroradio
