Clutch lever movement before engaging
OK, so I adjusted my clutch using the service manual and the "easy" method I found online. Now the question is:
At what point in the lever travel is the correct spot for the clutch to engage?
When I tested it, as I let the lever out, the bike starts to move in 1st gear when the lever is approximately 1 inch away from the bar. It feels correct, but this is my first clutch adjustment so I want to make sure I did it right.
Thanks!
Thanks!
Yup, what he said. As long as you have a bit (dime to nickle's worth on the lever fulcrum) you should be fine. The friction zone will be different depending on the machine and use. For example, I adjust the clutch the same (probably the "easy" method you mention) on both my bikes. But the Ultra with ~45K miles and the Softail with ~10K miles have about 3/4" difference in "feel" from the lever.
Your good to go.
If you want the clutch grab a little closer to the bar just back the adjuster screw on the clutch pack out a bit further next time.
BlackFLHR
05-05-2010 06:43 AM
ThePointman
03-13-2009 05:06 PM
