Check Your Saddlebag Securing Pins
Old 05-15-2010, 11:55 PM
jdreed520's Avatar
jdreed520
jdreed520 is offline
I also bolt mine on.......And you have to have a 1/2 wrench to get them off....
Old 05-15-2010, 11:56 PM
ashmarc's Avatar
ashmarc
ashmarc is offline
Originally Posted by hog-doc
They dont work themselves loose, they get installed incorrectly!
What he said……..
Old 05-20-2010, 11:13 PM
bagger05's Avatar
bagger05
bagger05 is offline
What they said
Old 05-21-2010, 12:37 AM
V2Evo96's Avatar
V2Evo96
V2Evo96 is offline
If they are not lined up straight into the spring they feel like they are tight but they are not latched. If you dont feel them roll over the spring then YOU didnt install it correctly. Once the spring is locked in they CAN NOT back out.
Same system used to hold 300 mph drag car bodies on, install them right they work!
+1 Absolutely correct-- A dzus fastener can't come loose if it is installed correctly. They will always want to tighten rather than loosen, which is why a bazillion or two are used on commercial aircraft.
The only way I think they would come loose is if the spring breaks which would be as rare a rocking horse ch1t....
Old 05-21-2010, 01:18 AM
NoCoLoco's Avatar
NoCoLoco
NoCoLoco is offline
True... unless the fasteners are defective or worn. If you find them way too easy to turn, one way or the other then you'd better replace them A.S.A.P.
Old 05-21-2010, 04:54 AM
VETERAN75's Avatar
VETERAN75
VETERAN75 is offline
I just put a stainless bolt, fender washer, and nylon locknut on the front side of each bag just to be safe.
I think the problems people had were with them breaking, the wire that the fastener hooked around had broken.
Old 05-21-2010, 05:30 AM
HDJIM1158's Avatar
HDJIM1158
HDJIM1158 is offline
Been riding with the OEM 1/4 turn pins since 1998 and never had one fail, however due to reports of theifs, I replaced one on each side with the ebay bolt, PIA but rather be safe than sorry.
Be Safe JIM
Old 05-21-2010, 06:24 AM
mikesth's Avatar
mikesth
mikesth is offline
+1 I did the same
Old 05-21-2010, 08:04 AM
jokenighttrain's Avatar
jokenighttrain
jokenighttrain is offline
Same here...allen head bolt, unut, fender washers. Good security and good safety. I keep a set of dzus fasteners in my bag just-in-case!
Old 05-21-2010, 08:29 AM
harley_badboy's Avatar
harley_badboy
harley_badboy is offline
I've never had a problem with mine but I always double check to make sure that the spring caught as pointed out by hog-doc.
Quick Reply: Check Your Saddlebag Securing Pins
