Crank Run Out Acceptable Specs
Old 05-15-2010 | 11:00 AM
SICKBAGGER's Avatar
SICKBAGGER
Default Crank Run Out Acceptable Specs
While I was changing my cams I did notice a little wear on the crankshaft where it rides in the brass bushing in the cam plate. It is not even and favors one half of the crank. I have heard many different run out specs and the manual states .010 when in the case and mine is at .008 but the wear is noticable. Depending on which manual you read these numbers are different. Also I have read that there are some Technical Bulitens out on this issue. What is a good reading what do the bullitens say?
Old 05-15-2010 | 11:08 AM
Eyespy's Avatar
Eyespy
From: Southern California High Desert, here and there....
That's too much run out for gear drive cams if that's the direction your taking. That crank would need to be straightened. BTW, spent the weekend out in your neck of the woods last weekend.
Old 05-16-2010 | 11:21 AM
SICKBAGGER's Avatar
SICKBAGGER
Eyespy,
Next time you come this way give me a heads up!
F86
04-19-2017 06:59 PM
Lsc8
Engine Mechanical Topics
07-23-2016 08:13 PM
03dragonRK
04-27-2015 06:29 AM
ntg433
10-17-2013 01:24 PM
jaguar
Ironhead
01-01-2007 09:27 AM
Quick Reply: Crank Run Out Acceptable Specs
