Removing Right Grip (Throttle Side)
Ok, I normally don't deal with grips cause I hate grip glue. But I want to change my grips and was thinking about one of the Harley grips that are "glueless". Great, no problem with the left, just slice it off and clean up the glue residue.
But, I've not dealt with the grip on the throttle side before. So, is it just as easy as unscrewing the switch housing and opening it up and pulling out the grip? Or am I missing something? Is the grip even attached to the throttle housing? I tried to look this up in my service manual (09 with TBW) but couldn't find anything about this.
Ditto.
Just open the two switch halves and pull on the grip, it will separate from the grip sensor in the bar end. Even easier than the older style with two cables. As for the left grip, don't cut it off. Open the switch halves again. Just put on some work gloves to get a good grip and try rotating the grip back and forth starting at the end closest to the switches. There is very little glue holding it on and easy to break free, once started. You can then save both grips for the future.
