Should I do this and is it worth it?
I've pretty much decided on doing the SE-255 cams on my 96" 2009 RKC. It already has SE air cleaner, SEST and thunderheader. While installing the cams I'm also thinking about putting on the cometic head gaskets? Does anyone know how much this will boost compression/performance? Is it worth doing and will it cause any hard start issues or would I need compression releases? Thanks…
Your plan for the SE255 cams and using the cometic gasket probably won't get you more compression/ performance that you would be able to notice, for the money involved. You won't need compression releases with just the cams and the gasket or have starting issues. Plenty here have just put in the 255's and gotten what they wanted.
Don't know how much it means to you to have more compression but, if you plan on pulling the heads, why not put in high compression pistons. This would allow for higher lift cams and boost your performance. It's all about how much money you want to spend and where you want your performance. If your plan involves more motor work later on, try to think ahead a little. Planning a build will produce better results with the more information you have and take your time. Good Luck
"typical high compression motor problems" What problems? Many people are running high compresssion motors way bigger than mine and have no problems. I can run the mountain highs or seacoast lows, no pinging, nothing. If you have the proper tune you should not be afraid of high compression, that's where you get TORQUE. But, I understand you want the SE255's and that's the right choice for you. Why don't you PM Ultracla$$ic.
lp
