To Autotune or not to autotune?
Old 05-12-2010, 11:01 AM
Shark92976's Avatar
Shark92976
Shark92976 is offline
Default To Autotune or not to autotune?
Anybody have any experience with a power commander PCV with and without the Autotuner? What were the major advantages of using an autotuner? Did the bike run any better/different with it installed? Thanks in advance.
Old 05-12-2010, 11:06 AM
DR. V-TWIN's Avatar
DR. V-TWIN
DR. V-TWIN is offline
Former Sponsor
This is a mixed bag. Some people love and others don't. If i were planning on Autotune, I would get a TTS and do it that way. TTS is $425 for one bike. That being said since you already have a PCV, do some research.
Old 05-12-2010, 11:14 AM
Shark92976's Avatar
Shark92976
I'm looking for answers more directed towards the actual benefits of the autotune compared to not using one. Is it worth the money? This is research isn't it?
Old 05-12-2010, 11:25 AM
pled55's Avatar
pled55
pled55 is offline
look for or search for post by iclick he has the whole story from day #1 on pcv autotune
you name it he's tried it. and has some really good info.
Old 05-12-2010, 11:29 AM
iclick's Avatar
iclick
iclick is offline
First, TTS isn't part of the OP's question, but since it's been brought up it should be emphasized that it does not auto-tune. It works with the stock narrow-band O2 sensors and will allow closed-loop operation in about half the throttle range, not beyond about 50% TP, just like stock. It's also limited by the AFR range, as in closed-loop it can't read richer than 14.2:1. That would work for many, including me, but some want richer AFR's in the cruise range.
PCV-AT is different in that it auto-tunes AFR's throughout the RPM/TP range and between 11.0-16.0:1, well within the range of anyone's requirements. It is more accurate than the PCV alone because it tunes on the fly, i.e. in real time, but I doubt seriously if anyone will notice a difference compared to a PCV without AT that is properly tuned.
Where AT fits in well is for riders who will be making changes to their configuration over time, like a cam change, and don't want to dyno-tune after every mod. With AT you just do the mod and ride. Ignition timing may need some adjustment, as that doesn't auto-tune, but it usually doesn't require a dyno-tune to optimize. Keep in mind that the bike's stock knock-sensor is fully functional with the PCV with or without AT.
AT is also for people like me who are addicted to tweaking. For example, I like to maximize mileage without affecting roll-on performance, and although you don't need AT or even a PCV to do this the AT upgrade makes it much easier. Using it with a map switch allows toggling between open-loop and closed-loop modes on the fly, and that's a big plus for me, as you can tune the base map rich for cooling, leaner in AT-mode for mileage. The PCV alone with allow toggling between two base maps.
Here are two links that might help:
PCV-AT, install and first impression
Tweaking the PCV-AT for mileage
Old 05-12-2010, 12:06 PM
Shark92976's Avatar
Shark92976
This is exactly what I was looking for, Thanks!!
Old 05-12-2010, 12:50 PM
harleytuner's Avatar
harleytuner
harleytuner is offline
IClicks got it down pat. The PCV with AT is great for people that want to plug it in and ride their scoot. The TTS with V tune is great for the people hat like to keep tweaking their bikes. I know peole that Y-Tune get their bike running sweet and still have to keep messing with hings. Always looking for more. It's a fine hobby, but if you'd rather ride and don't want to learn a whole lot about VE tables, timing and all that, get the PCV with AT and enjoy your bike.
Old 05-12-2010, 01:25 PM
WI Bob's Avatar
WI Bob
WI Bob is offline
Plus one on what I-click said about the PCV autotune.
I haven't played with the TTS....yet.
Old 05-12-2010, 02:52 PM
Mike's Avatar
Mike
Mike is offline
I've only had mine for about a month. I really can't say for sure yet whether I'd recommend it to someone else. I'm still trying to figure out how it all works. I had a fuelpak on my bike previously, but it can't handle most cam changes, so I went with a Power Commander V. I haven't really seen any change in performance, other than a loss in fuel mileage. I know I could email fuel moto for map help, but haven't done that yet, so it's certainly not their fault. I'm letting the bike autotune and accepting the trims periodically, hoping to see what that does before I start monkeying around with the map.
Old 05-12-2010, 03:06 PM
Shark92976's Avatar
Shark92976
Correct me if I'm wrong, I'm just learning about EFI. Doesn't the PCV autotune use the installed map as the basis for the autotuning? So if you did a cam swap it would still only tune the AFR to stay in the range of the specified in the MAP. so if your map was a little lean, which it doesn't appear that it is according to your fuel mileage, but if it was I could see how a tweaked fuel map would help. Or does it adjust itself to run the most effieciently? Does fuel mileage mean it's running rich?, or could it be that the MAP you currently have needs tweaking to run optimum, and then let the autotune keep it within those ranges in "real time"?
Hope that made sense!
Quick Reply: To Autotune or not to autotune?
