Amp connection help
Amp connection help
Ok I'm installing an after market amp. I am using the stock head unit. DO I use the high level speaker input to the amp or do I get a speaker level to rca connector and use the low level input ? What is the difference ? Sorry not an audiophile, just a guy that wants loud jams.
Hi,
If you have the RCA connectors use it as it will give you a cleaner signal.
The difference between the two is that the high level inputs will output a full signal (distortion and all) when the radio is turned all the way up whereas the low level will put out a clean signal for your amp.
Mike
Mike
