twin cam motors are junk
Old 11-16-2015 | 03:16 PM
mister Crowley's Avatar
mister Crowley
Originally Posted by jdot
I purchased a 2005 Electraglide standard new, I've keep it serviced and have ridden it with respect. NOW at 43,000 miles it starts knocking, so it needs cam bearings and possibly lifters valves and who know what else. As much as they cost you'd think they would go at least 100,000 mi. but I guess the UNION wants them to fail so they can build more new ones. When it's fixed I'm selling and purchasing an EVO.
Wise move.I've got a 92 fat boy that I'll never part with.Got 120000 on the clock and still problem free.
  #92
Old 11-16-2015 | 03:40 PM
Ron750's Avatar
Ron750
This thread is 5 years old. OP hasn't been on in 3 years.
  #93
Old 11-17-2015 | 07:33 AM
Quadancer's Avatar
Quadancer
So what; the Hogs will live longer yet. My '05 tc88 has a Boyesen X-wing b4 the carb, tuned jets, 2-1 pipes, an Andrews 21 torque cam, and others have thought it was a 103 because of the way it runs. I expect to see about 150k b4 I bore her out and rework the heads and bearings.
It rocks when your powerband comes on at 1400 revs!
  #94
Old 11-17-2015 | 08:04 AM
roussfam's Avatar
roussfam
Seeing how this thread is 5 years old, I guess it's safe to hijack it.
Boysen X Wing! ROFLMAO. ;-)
  #95
Old 11-17-2015 | 11:19 AM
hvacgaspiping's Avatar
hvacgaspiping
Originally Posted by Northside
Evo's bulletproof? I seem to remember Evo lifters being good for about 25,000 miles. They were finally upgraded to a larger axle for the roller, not to mention weeping cases, and leaks at the cylinder bases. The Twin Cam oil system is far superior to the Evo's, and O rings at the cylinder bases don't seem to leak. The Twin Cam's only Achilles heel was the old spring loaded cam chain tensioners which has been corrected with the hydraulic tensioners. The earlier models are easily upgraded with gear drives or the later hydraulic set up. I have two twinkies and they have been the most dependable motorcycles I've ever owned, and I've been riding over 40 years. Twin Cams ain't junk!
They would be a lot better if Harley would put decent main, oil pump and cam bearings in them instead of cheap Chinese junk. That`s the crux of the Twin Cam engine problems.
  #96
Old 11-17-2015 | 02:49 PM
harley0711's Avatar
harley0711
How far did you have to search to pull up a 5 1/2 year old post?
  #97
Old 11-17-2015 | 03:32 PM
hoethree's Avatar
hoethree
69k solid miles on my twincam 96 stock motor, it will hit 100k before I open it up and rebuild, IF NEEDED.
  #98
Old 11-17-2015 | 03:34 PM
hoethree's Avatar
hoethree
damn! this is a 5 year old thread.......duh. Did he buy a Honda?
  #99
Old 11-17-2015 | 03:39 PM
clackavosticus's Avatar
clackavosticus
Default Subscribed
Subscribed
  #100
Old 11-17-2015 | 05:09 PM
brokefootkenny's Avatar
brokefootkenny
Look for the union label...........local 399 IUOE, chicago
Only time in my life I haven't carried a union card is when I was working for the Commandant of the Marine Corps.
Quick Reply: twin cam motors are junk
