Would you get your bike redynoed ??
Would you be happy with a dnyo sheet like this or get it redynoed ??
2004 Harley Davidson Ultra Classic TC 88 with 12,000 miles and....
Rinehart True Duals
Screaming Eagle air cleaner
Power Commander III
Head Quaters 0034 cams
Head Quaters lifters
Head Quaters gear drive
Head Quaters black ops lifters
Fueling cam plate
Fueling oil pump
Here is the dyno sheet...
Rinehart True Duals
Power Commander III
Fueling cam plate
Fueling oil pump
Attachment 115673
Here is an updated dyno sheet in SAE form along with my Air/Fuel ratio chart. So what do you think ???
Rinehart True Duals
Power Commander III
Fueling cam plate
Fueling oil pump
Rinehart True Duals
Power Commander III
Fueling cam plate
Fueling oil pump
Rinehart True Duals
Power Commander III
Fueling cam plate
Fueling oil pump
Rinehart True Duals
Power Commander III
Fueling cam plate
Fueling oil pump
Revised dyno sheet in SAE form along with Air/Fuel ratio chart. What do you think ?? Redyno or leave as is ??
Sorry I tried to make it darker so you could see the Air/Fuel ratio lines.
I responded to your e-mail, but i'll say it here as well. Your A/F line looks lean, the tuner made 4 passes on your bike to get it to where it is. What you are looking at is just the wide open throttle run (and just 1 cylinder), we have NO way of knowing what your bike is doing at cruising. If he tuned it lean at WOT who's to say it's not lean at cruising.
