Any body thinking of buying that hd oil filter funnel?
dont....LOL...
in a moment of weakness, I bought that silly oil catcher thing for when you remove the oil filter....damn thing made more of a mess than I ever did with any other method...
I take a 10"x4" or so piece of card board when I do my oil changes and slide right under my filter when i take it off and lets the oil drain right out past the frame and into my oil pan. Works like a charm for me.
+1 The very first maintenance lesson I learned. I was tempted when I first saw it, but
next thing ya know I'll be buyin' the fuel filler cup thingy
I use a two liter bottle. Lay it on the side, cut the bottom off and cut a fourth or so section of the body of the bottle away almost all the way to the pour spout. Now you can slip it underneath the oil filter mount. The oil runs down the inside of the bottle and out the same hole that good ol' Mountain Dew used to run through.
I use a two liter bottle. Lay it on the side, cut a section out of the top all the way to the end and slip it underneath the oil filter mount. The oil runs down the inside of the bottle and out the same hole that good ol' Mountain Dew used to run through.
+1 Read about this trick on this forum some months back....
