clear coat repair!!!! help!
I'm gonna puke.
I scratched the lid of one of my bags. it looks like it's just deep clear coat scratches.
I bought a product by turtle wax that includes a clear coat pen, 3 different buffing pads, a buffing lubricant and what appears to be compound.
anyone ever need to use a clear coat repair kit and if so, what was your results?
does anyone have any tips that can help me out before I make matters worse?
they are pretty deep but disappear when wet down with water and I see no paint loss.
thanks,
Tony
thanks,
Tony
I detailed cars, boats etc for years
I detailed cars, boats etc for years and I have seen alot of those "repair kits" come in so I could fix there work. I'm not saying there bad I just never seen one work and that was years ago so maybe there better now to.
that being said i would leave it to the pros, with ought seeing the scratch its hard to recommend a process but if it isn't to far into the clear a skilled detailer can use a gritty compound to take the scratch down then polish er back up in 20 minutes to look like new again. if its on the bad side a simple wet sand and buff could also do the trick. if all else fails a wet sand and re clear coat but that's only if its real bad.
if you can get me a picture I can better point you in a good direction.
I think certain body shops have something called cutting compound or something like that. That my help depending how deep it is.
You also need to remember that at least on the newer bikes Harley does not spray their clearcoat on. It is a type of powder and then baked on.
I learned that on my visit to the York, PA plant where they build the touring bikes.
Trust me I know how you feel. Somebody won't mention names sat on my bike with hard boots and I heard him hit the bag when he put his leg over. Have a small scratch on the corner which is past the clear. I was sick to my stomach.
...agree with Scarpetta...if the scratch is real deep...just remove the lid fromt the bag..(it's easy)...and take it to a bodyshop and ask them to re clear it...it should be pretty cheap...I would say no more than $50.00 tops...but ask them to try and buff it first...and remember...an electric buffing wheel is gonna do a way better job than you can by hand...
lfalla, i think you are referring to powder coat but I think (correct me if im wrong) thats only on tins and the part your referring to is plastic or fiberglass right?
and I agree with jmacdonald5's price guess, round these parts it would be about the same. definitely under 100. well worth it to have your scoot look new again.
If you want to fix it real cheap, wash with soap and water dry real good.If it just into the clear coat use clear fingernail polish let dry and refill again. Use a tooth pick and just fill the scratch. Wet sand with 1500 wet sand paper.until smooth, be carefull the harley clear is not as thick as it used to be. Use a mild rubbing compound until all the 1500 scratches are gone and polish to a gloss. Have patience and it will turn out as good as new.
Try this http://www.motorcycle-armor.com/ No need to repair, covers the current scratches and eliminates future ones.
