Hi, has anyone installed one of these modules on a 2010 Streetglide yet? For the life of me, I can't figure out where it is supposed to go. I had one on my Fatboy that was pretty simple to install. Also, is it a straight plug-in or do I have to remove any of the HD pieces.
I have a 2010 Streetglide that is a Canadian Version and the set-up is the same as 2009.So the only brake lite is the main light on the fender and I would like it so that all the lights were Run Turn and Brake.
The module will light up your turn lights to run and brake, I added to that package red turn lights and removed the yellow lights, that should connect to your rear fender harness under your seat. Just unplug the harness and plug in your Kurykan module. easy monnnn!
