New sest with smarttune issue
seems like it is within the progam
I'm not real good with the computer. I have checked in the my computer c- drive and don't see it. seems like it is somewhere within the hd software program if that makes any sense. **** me off some of this computer stuff.
I'm thinking it is going to be interesting. How many times do you think that you need to smarttune after the base map is installed? When you go in for the hd download after you put an air filter and exhaust on is it one of the ones that they give you in the files of this software?
I have also heard that some use the HD download for the 103" for the 96" motors to reduce the AFR a little more for the stock motor with the A/C and exhaust upgrade.
It depends on how close the base map is to what you need. I did 5 on mine, and want to do 1 more when it warms up. The last couple runs did not make much of a change. The stage one map is one of the ones included.
Stored calibrations
I've gone as far as removing the software twice today and reinstalling it. I am missing something they keep reappearing in the stored calibrations i can move them over there but can't get rid of them. After four maps are in there it starts dropping one and adding the new one you bring over. Is there a possibility that you can't remove them from the window in stored calibrations just add new maps as you need them? These are just the maps that are in the software they give you with the disk that i have moved over to the calibration box by checking manually pick a map.
You'll need to follow the path in the file name. It's actually quite easy to delete the file but I'm not sure where you're currently saving them on your computer. The file path name will tell you exactly where it is on your computer.
File path name
Is this it? C:/programs data/supertune/delpi/tuning files/Bigtwin/009caf002dto I can't seem to locate it. It says that the window that i have them in shows the last four maps that i have veiwed they probably don't matter but it just irritates me that i can't remove them even uninstalling all the software. So i'm missing something during the uninstall process. I wouldn't think that something has to be removed from the registry. Where are your files stored i just let the program put them where it default does. Have you ever tryed clearing them on yours? Thanks for your help with this.
If you have maps that you created yourself and want to delete, then you need to find the path where the files are stored. I set a folder up on my desktop where I keep all the maps that I have created from Smarttuning. My recommendation is to use "Search" and find all files on your harddrive with the extension ".dt0".
Do not touch your registry. The files are are on your harddrive and you need to read the path of the file from the ST software and then follow that path to the files. It really shouldn't be that difficult. Use the search function and you should find them easily.
Thanks
The files in the BigTwin folder are the maps that come with the software. You shouldn't delete those as someday you might want them.
Springerkidd
10-10-2013 07:18 AM
sbkjo
06-03-2008 03:20 PM
