rear axle nut size?
rear axle nut size?
Was measuring the rear axle nut on my 06 ultra classic electra glide with a cheap caliper and without disassembling anything - not quite ready to start work, and can't get caliper exactly straight without disassembly. It appears to be 1 1/2 inch in size. Looking to draw on experience for the proper size to get the right socket.
Thanks for any info.
Regards
Denny
Regards
Denny
500hertz (01-28-2020)
There should be a wrench in the tool kit that came with your bike.
Also there is a special wrench to use with a torque wrench so you can tighten it without removing the exhaust. Several different brands, including H-D, I bought one on E-bay.
You do need to lower the exhaust and remove the saddlebag brace on the left side to slide the axle out.
I think there is creeping metrication. From 2008 wheel bearings and axles have been 25mm. You have to bear in mind most of the rest of the world is already metric, also in 1975 President Ford signed off a metric law in the USA. He just forgot to say when! Seems it is beginning to happen....
