Question about LED Signals and BAL Brake Light
Well, I just installed my NEW BAL-3S tail light and Street Magic front and rear LEDs all wrapped up in new smoke lenses. I replaced my Kuryakyn Panacea system with this setup...I liked my Panacea system UNTIL I saw a BAL in person going down the road. I saw it before I could tell it was a bike at about 3/4 of a mile!
Got the HD Run/Turn/Brake Module with a Badlands Load Equalizer. The signal lights are Street Magic Genesis II's by Custom Dynamics.
Here are some pics.
Front
![](http://img.photobucket.com/albums/v319/mikefragala/Road%20Glide/DSC00572_resize.jpg)
Rear in RUN MODE
![](http://img.photobucket.com/albums/v319/mikefragala/Road%20Glide/DSC00575_resize.jpg)
Rear in BRAKE MODE
Here are some pics.
Front
Rear in RUN MODE
Rear in BRAKE MODE
![](http://img.photobucket.com/albums/v319/mikefragala/Road%20Glide/DSC00577_resize.jpg)
Mike, I have the BAL-1R (essentially the basic Bright *** tail light without a clear window for the tag) and the HD run/brake/turn signal module. Everything works. A long time ago I replaced the turn signal bulbs with some inexpensive LED's without a load equalizer and used the run/brake/turn signal module so long I can't remember when it was installed.
Don't know a thing about load equalizers.
Carl
Carl
Carl
Carl
I took all the Kury stuff off. I have a Badlands plug and play Load Eq, fairly new. I just need the Run/turn/brake module. Don't see the need to replace the Badlands I have for one with the module when I can snag a module from HD for $30? Do you?
I don't know if the HD module has a heat problem like the Kuryakyn one. If it doesn't, then you would be ok with it. ato find out, try running your flashers for a minute then feel it. Of course, by then it may be too late. Maybe someone else will chime in on the HD controller. I do know that there are no issues at all with the Badlands, it's also alarm compatible.
The Badlands is ceramic the Kury is not...ANYWAY, my question is specific to the HD run/turn/brake controller and BAL light. There are loads of people on here using them...genesis lights too.
