Photos of Street Glides w/ the tourpak
RE: Photos of Street Glides w/ the tourpak
ORIGINAL: Garrison1383
Part numbers would be great if you have them.........................
53270-06BXT -- FLHX King Tour-Pak, Deep Cobalt $675.00
53276-04 -- Detachable Tour-Pak Mouting Rack $169.95
53804-06 -- Docking Hardware Kit $54.95
51634-06 -- Backrest, Tour-Pak, FLHX $209.95
DS250034 -- Electronic Hidden Antenna $80.99 (not a H-D part#)
53848-00 -- Tour-Pak Lock, Keyed to Lock $20.49
53641-02 -- Lock Support Washer $0.49
84850-92 -- Nut $1.99
53617-85 -- Guide, T/P&S/BG FLTC, HTC, HTP $2.49 (I have no idea what this is)
90686-92 -- Tour-Pak Cam Hook $2.49
Parts Total $1218.79
Incidentally, they quoted me $445.00 to install this stuff (8 hours @ $89). I'm not paying them to install it.
Buy all the stuff from chicago HD or Zannoti's, save at least 20% plus tax.
You only need the top 4 items. The antenna you have will work, just need a short extension.
What the hell is a tourpack cam hook?
It's nothing but fun putting it all together.
Here are some pictures of my King Tour Pac with the quick connect 2 up detach kit installed. Takes about 4 hours to install when your drinking lots ofbeer and your sweating buckets in a Garage that's seeing100+ temps! Below is a list of parts including links for the seats and tour pac backrest.
Here is the parts list:
Ijust took delivery of a King Tour with a 2-up detach kit and here is a list of parts needed if you want to do it right.
53270-06BPS King Tour Pak - B(Black Cherry Pearl) $803.21 CDN
53276-04 2 Up Detachable Tour Kit $203.96 CDN
53804-06 Docking Hardware $67.11 CDN
76326-00A AM/FM Antenna Relocation Kit $136.81 CDN
53848-00 (add key code) Tour Pac Cam Lock $33.11
53641-02 Lock Support Washer $1.66
84850-02 Lock Nut $3.36 per 10 pack
53617-85 Lock Guide $4.21
90686-92 Lock Cam Hook $4.21
Total cost of parts for me in Canadian Dollars $1333.10
I have the backrest seat pad from Mustang that matches my seats. Better quality than the HD backrest and less $$$ too if I am correct. In either case, you'll need one of them too so don't forget that part of the wife may be unhappy. I went with the king tour cause it's only going on for 2 up rides and touring, and I want the storage. When I ride solo, it comes off!
Good luck.
It's the smooth solo seat with backrestwith the accompany of the wide passenger seat. Below this is the plain smooth backrest, but niote that this setup only fits the king tour pac. Part numbetrsand related info are below. Mustang make a great product, andIMHO they are anoutstanding company!
__________________________________________________ __________________________________________________ ________
Plain Solo Seat with Driver Backrest and 14 " Wide Plain Recessed Passenger Seat [align=center][/align][align=center]Note: Solo Seats and Recessed Passenger Seats are sold seperately[/align]
Enlarge Plain Solo w/ DBR
79127 - 17" Wide Plain Solo
......................w/ Driver Backrest
[blockquote]
$489 (Solo Only)[/blockquote]
79110 - 14 " Wide Plain
......................Recessed Passenger Seat
[blockquote]
$189 (Passenger Seat Only) [/blockquote]
Extended Arm FL Wrap-Around Backrest
Designed for quick, direct mounting to FLT and FLHT Tour Packs 1986-2006. Rubber washer mounting system eliminates the troublesome soft stock isolators. Arms are extended an extra 2" for added comfort. Thicker foam padding provides comfortable armrests. Can be mounted to 1980-85 FL models when Tour Pack is relocated further back. [align=center][/align][align=center]NOTE: Will not fit leather or chopped Tour-Pak.[/align]
Enl
Good luck.
ORIGINAL: GliderXXX
Glideman...is that the Mustang sport touring or the full sized touring. Your bike looks great.
[blockquote]
[blockquote]
Enl
