clinking sound from front of motor
Old 05-06-2010, 10:20 PM
RKC2010's Avatar
RKC2010
RKC2010 is offline
Originally Posted by Mick
If you hear a sound like clacking (clackity clack ) on the left side , have the compensater bolt checked to see if it's loose (mine was) at 6,000 miles.
I also had a really bad bang type noise every so often when hitting a small bump which ended up being the 2 lowest fairing screws near the lower triple tree , they had loosened and made noise totally out of proportion to their size.
Check the jiffy stand hardware for loose fasteners also.
Just what I've noticed so far......
Mick
Have that noise also, only at real slow speeds like in a parking garage.
Old 05-06-2010, 10:23 PM
JWitz's Avatar
JWitz
JWitz is offline
Mine did some pinging under similar conditions...the pipes. SERT and Dyno took care of it....
Old 05-07-2010, 12:13 AM
imskier2's Avatar
imskier2
imskier2 is offline
Wear a good full face helmet and the noise will go away.
Old 05-07-2010, 10:23 AM
MNAY0227's Avatar
MNAY0227
MNAY0227 is offline
Originally Posted by O-O
I have an 09 ultra and just noticed a clinking sound coming from the front part of the motor. sounds sort of like a metal clink like when a stone hits a metal part of the bike. only notice the sound when in 5th or 6th gear and accelerating going anywhere between 60 and 80 mph. what could this be.
Tim a.
Having the same thing going on i do run 93 octane, its under acceleration that i hear this, mine is a 07 road king. O-O let me know what you find out.Thanks.
Old 05-07-2010, 10:37 AM
Retired Navy's Avatar
Retired Navy
Retired Navy is offline
You might want to tape the vents on the lower fairings in the open position to see if they are "rattling" in the wind. I had a similar problem with my '08 Ultra and it was the friggin' lower vents floppin' around!!
Old 05-07-2010, 08:40 PM
RKC2010's Avatar
RKC2010
RKC2010 is offline
What's up Mike? It's been a long time since I've seen you post. Where you been?
Old 05-08-2010, 08:30 AM
MNAY0227's Avatar
MNAY0227
MNAY0227 is offline
Nothing much David just working starting to get some riding in.Yeah i hope i can figure out this issue with my bike.It's starting to **** me off when passing a car and this noise starts a little embarrising.
Old 05-08-2010, 08:34 AM
Skulmn's Avatar
Skulmn
Skulmn is offline
It is "pinging".. And you need to be using 91 or greater octane...With all the ethanol and junk going into gas, I would venture to say that 91 isn't even 91 anymore, probably less.
Also, make sure when you accelerate you are not below 2000 RPM, lugging the engine will also cause pinging and damage.
Old 05-08-2010, 09:02 AM
O-O's Avatar
O-O
O-O is offline
Didnt go to dealer yet. did try running 93 octane ran 2 tanks thru and still does this.if it is octane grade maybe it takes some more tanks full to stop pinging.will let you know what i figure out.
Old 05-08-2010, 09:08 AM
O-O's Avatar
O-O
O-O is offline
looked that over already when i was checking every thing to see if something was loose. the only thing loose was the three screws that hold the windshield on. and the kick stand seems to be real floppy. Did think of something else it might be my guardian bell i have right on the front frame bouncing up hitting the frame. will try that.and see
Quick Reply: clinking sound from front of motor
