Yet another PCIII USB question
Old 05-05-2010 | 10:25 AM
sargek's Avatar
sargek
Originally Posted by nvsteve
Fuelmoto is the largest seller of Power Commanders. They also sell there own branded unit which is a modified PC. You said you bought the bike used so I assume you looked behind the cover to to see for sure you have a PC.
There will still be a cable attached at the 02 sensor but will be disconnected at the other end.
Fuelmoto, even if you didn't buy it from them, will likely help you. They are know for it.
If you don't have the eliminators you will need to buy them anyway so give them a call.
Yup, it's a PC for sure - it looks just like the ones on their web site and has the 3 "high medium and low" buttons. I'll give FuelMoto a shot - sounds like they are very helpful. Thanks.
Old 05-05-2010 | 01:12 PM
nvsteve's Avatar
nvsteve
Good luck. Let us know how you make out.
Old 06-11-2010 | 09:11 PM
sargek's Avatar
sargek
OK, mystery solved. Bought a 9 volt adapter and some O2 sensor eliminators. Got the laptop to see the PCIII finally and downloaded the map. The map was the stock 2007 Powercommander "canned" map. Since that is not what I have, I loaded the map for the SE AC and V&H slipons. I don't have those slipons but it was the closest thing with the SE AC. The map file is "M812-003.djm". The bike starts and runs - we'll see how it does in the morning when I go to work.
2heritagespringers
02-17-2012 06:41 AM
hdpearl70
01-26-2009 09:49 AM
vascik883
01-11-2009 01:54 PM
Kockdiesel
08-12-2008 06:34 PM
skratch
05-29-2008 01:52 PM
Quick Reply: Yet another PCIII USB question
