Let's talk center stands
So at the Timonium show, I was wowed by the Wheeldock E-Z Up Center Stand. It's a nifty piece of engineering that's a snap to get the bike up on and back off of. I know several people who swear by theirs.
The MoCo offers one too.. And it's adjustable, so I can set it low for fueling and such, then crank it up for service and cleaning.
The prices are nearly identical if I get the Harley one from an online dealer. Any pros-cons for either one?
I have the wheeldock also. Just so you know, I do not use it as my "all the time" stand when parking away from my home. I do use it in my shop on the nice flat floor. If the surface is at all bumpy, the bike can roll off the stand fairly easily. I also always leave my bike in gear when I park it on the stand. Lastly, the stand does come with a velrco strap to lock the front brake lever so the bike won't roll off.
If you do a search, you will find several people making the same statement.
I like to use mine when fueling and when I ride with my wife. Makes it easy for her to get on. I am ALWAYS on the bike when she gets on.
The wheeldock is an easy 2 bolt install. The bolt heads are in the crossmember so my J&S jack does come up against the bolts when I lift the bike. Not an issue if I'm careful.
Steve
Steve
The wheeldock is an easy 2 bolt install. The bolt heads are in the crossmember so my J&S jack does come up against the bolts when I left the bike. Not an issue if I'm careful.
Steve
Steve
Lots of threads on this subject. I love my Wheeldock. It will occasionally nick the ground if you're cornering hard and pass over a dip in the road. Nothing serious. As long as you don't do something foolish like park downhill in neutral or on uneven surfaces it's rock solid. Always use it in the garage and at gas stops.
