Screw in rear tire but not flat what to do?
Old 05-02-2010, 04:40 PM
DanDil's Avatar
DanDil
DanDil is offline
Default Screw in rear tire but not flat what to do?
I have a RKC with brand new E3's with 75 miles. I stopped for gas a noticed something on the rear tire and it was a 1" small thread wood screw in my rear tire, in on an angle about 3/4 into the tire. I backed it out and did the spit test and no air was comming out. I headed for home and stopped after 10 miles and cheched the air and was still ok. I think it missed the tube. I parked it in the shop and will check for a leak. I the tube is ok, I now have a tire with a very small hole with a good tube. For peace of mind (when I'm doing 80 on the interstate) should I replace the tire? What would most you guys do? I wanting to replace the tire & tube...is that over reacting? If the tire wasn't brand new, I'd just replace it.
Old 05-02-2010, 04:44 PM
EdwardK's Avatar
EdwardK
EdwardK is offline
If you pulled the screw out and it's not leaking air with the spit test, you're good to go. More than likely, since the tire was new, it only penetrated the rubber (that wears eventually anyway) and never made it to the belts inside. I'd ride it and not even think twice about it.
Old 05-02-2010, 04:45 PM
EasternSP's Avatar
EasternSP
EasternSP is offline
Veteran: Marine Corp
Received 24,869 Likes on 9,332 Posts
Hmmmm, well seeing as its your bike, I would say just ride it till sumpin happens. If it was mine, I would take the tire off the wheel and have a good look at it.
CWDoc115's Avatar
CWDoc115
CWDoc115 is offline
In my mind no leak = no problem.
Old 05-02-2010, 04:58 PM
psychocircus's Avatar
psychocircus
psychocircus is offline
pull the screw out and see how long it is...
Old 05-02-2010, 05:06 PM
rogerfromco's Avatar
rogerfromco
rogerfromco is offline
Remember, the tire is a critical safety feature and ignoring it is just asking for Darwin to step in. I'd pull the tire off the rim and see if it went all the way through.
Old 05-02-2010, 05:13 PM
Big L's Avatar
Big L
Big L is offline
Pull the tire dude and check it out, we don't want another Biker went down thread started.
Old 05-02-2010, 05:25 PM
oldbiker771's Avatar
oldbiker771
oldbiker771 is offline
I plug the back ones with a plug kit available at any car parts store. Lots of people freak if you talk about doing that on a bike, but in the last 20 years I havent had a problem. Front ones I replace, regardless of mileage.
Old 05-02-2010, 05:35 PM
SeniorChief56's Avatar
SeniorChief56
SeniorChief56 is offline
Veteran: Coast Guard
Received 17,577 Likes on 5,089 Posts
it will always be on your mind if you do nothing,,,,,because you know something will happen
Wassup8687's Avatar
Wassup8687
Wassup8687 is offline
For the price of a tube I'd have a new one installed.
Quick Reply: Screw in rear tire but not flat what to do?
