Screw in rear tire but not flat what to do?
It makes no sense to pull the tire and plug it. If it isn't leaking, I would not do a thing to it. Run it like you stole it. If you do pull the tire off, put a patch on the inside of the tire if there is a large hole. But I would not pull it at all. I don't understand anyone saying to pull it off and plug it. A plug is OK to get you home, but if you pull the tire off, PATCH it and be done with it.
Now you're talking! I would patch it with that and roll on, never think about it again. A patched tire is as good as a brand new one, unless there was a tear or large hole. Then ya ****-can it and start anew.
