something new after i change over from my v and h slip ons to rineharts on deceleration intermittantly has a popping only during decel, i got a map from fuel moto usa what and how can i tweak the map to get rid of the decel popping
maybe i will try the map dynojet recommended and post results
In the "0" % thottle column of both fuel tables try putting 15 from 1500 rpm on up ( the present value is 0.) That took care of my decel popping, and was suggested by Jamie @ FM.
Add fuel to your zero and 2% percent throttle column from 2000 rpms up. Start by adding ten or so to each cell, ride, repeat if needed untill it is gone. Make sure if you are in advance mode to do both cylinders.
