Advice: Air/Download worth the upgrade?
HD: 2009 FLHR
Situation: V&H slip on pipes installed; bike sounds good.
Questions:
* If the air cleaner is upgraded to SE and the download is done, will the bike be louder?
*perform better?
*If so, is the difference worth the upgrade? How much does it costs?
Thank you for your time!
Questions:
*perform better?
The bike will perform better and it may be slightly louder.
The Download varies from dealer to dealer but is usually around $150
The SE air cleaner is $139 but can be had a bit cheaper at some of the online HD shops.
Your bike will still be EPA compliant which means it will run lean and hot.
A better way to go is with fuel management sytem such as a PowerCommander or SEST or TTS mastertune and there are a few other worth considering .
Hope this helps Tim
Hope this helps Tim
