Is it critical to change the o-ring
Is it critical to change the orings on the drain plugs for the oil and transmission or can I get by without doing so?
EDIT (45 replies later)
Ya know, it's funny - I posted this on a Sunday while I was itching to change out the fluid - but, I only had the fluid and oil filter and not any o-rings and of course the HD shop is closed and I wouldn't be able to get there or anywhere else for a few days - so, I thought "why not ask if it's critical to change them out" and WOW! Look at all the replies!
Didn't change fluids - in case I find that the old ones are bad, I will wait until I GET THE O-RINGS! Even though plenty of folks don't do it every time, as many have said...it's only pennies for added insurance!
__________________
__________________
Received 75,737 Likes
Cost of o'ring = pennies
Cost of aggrevation = whatever you value your personal time at
Cost of replacement oil = depends on what you are using, say $20 min
I don't see why it is worth taking the risk
If I were stuck on the side of the road, yes I would re-use it and would not have a lot of concerns
If I were planning the job in advance and had time to get the bits hassle free, that would be a no brainer
I re-use mine if there is no visible cracks or tears. You don't need a microscope to see a defect bad enough to cause a leak. I also wipe a little PTFE pipe compound aroud the plug and have never had any trouble. I keep some extra O-rings around so if one is found to be bad when doing a fluid change I don't have to make a special trip to get one.
