Is it critical to change the o-ring
04-28-2010, 05:17 PM
Never changed one. No problems.
04-28-2010, 05:53 PM
Only if the old one leaks.
04-28-2010, 06:03 PM
You should do exactly like the manual says because you will get cooties if you don't!
lp
04-28-2010, 06:13 PM
I replace mine because I riff on it and mark it up...Home depot..cheaper
04-28-2010, 06:22 PM
I usually change the drain plug as well. Change the pan every 20k just in case.
04-28-2010, 06:37 PM
I change O rings every time I change a fluid plus wrap plug with teflon tape. Such cheap insurance.........
04-28-2010, 06:48 PM
You'll void your warranty if you don't put new ones on.
04-28-2010, 06:50 PM
I replace after about 5 changes depending on condition. Always use high temp thread sealant. No leaks as of yet. Just go get a few to have on hand, if you want or need to change it no problems.
04-28-2010, 06:53 PM
The one on my oil drain plug is always messed up.
04-28-2010, 08:37 PM
74,000+miles on the original o-rings and derby gasket.
