Your 6th gear light go out?
E-
On some tuners there is an adjustment to set the Primary Ratio. If the setting is off then 6th gear will either not work or be sporadic at best. Not sure if the PCV has this option or would interfere with the VSS.
The VSS could be failing. Test your cruise control to see if it works when your gear light goes out. That will help you to zero in on the issue.
Thanks for humoring me..
Received 75,770 Likes
Sent question to Power Commander about this and they said their unit could not cause any of the Harley advisory lights to work or not. I told them I disagree because when I was doing the gear position calibration I could make the 6th gear light go out. Got a smart *** answer from the tech that I am dealing with his boss about now. Checked my diagnostic codes and only have the 3 for the O2 sensors being disconnected for the PC-V.
Called Harley and they said they were unaware of this even though I told them the service manger at Eastern Shore Harley told me he had one bike doing that too that Harley was investigating. My dealer's service manager said wait for the recall notice. WTF!
Location: LI, and New York, NY -- N 40 44.985 W 73 00.910
do not trust the dealers knowledge on these things.
the lesson that is being drilled into my head now is...
do not trust the manufacturer's knowledge on their own items!!
i find that i get more information here on HDF than anywhere else!
Mine has done it 3 times. The first time was on my way home from the dealer right after the 1000mi service. The cruise control does not work on mine when the 6th gear light goes out. I pull over, kill the bike, restart, and it works again. I also had the dealer adjust the clutch internally during the 1000mi service because the bike didn't want to "down shift".
My 6th gear light would go out intermittantly. If cruise was on, it kicked off also. Dealer replaced clutch perch and clutch switch which didn't help. Eventually they traced the problem to a bad connection at the HD running light module plug. They said they just cleaned plug and reassembled using dielectric grease, no problem since.
