ignition switch problems
I could sure use some tips. 06 Ultra I parked in my car port as always with no problems. 2 days later I went out to ride my bike to work and the ignition switch is off in the lock position just like I left it. However my key will not turn the switch, it just wont move at all. I've tried moving the bars, tapping the switch wiggling the switch short of a big F N Hammer I don't know what to do. Any ideas at all? Shoot I can't even get it to a shop I cant get the thing out of my car port. What a class A bummer!
Ok I got a call from a guy I work with a HOG member you know the guy that knows everything the one that has seen it all yeah that guy. He says I hear you got an ignition problem, so I tell him about it. He says yep seen it many times here's what you need to do get a mid size screw driver dont matter flat head or phillips, take the plastic end and on top of your switch right in the middle there's a bar and shield logo. Take the screwdriver and give it two firm smacks not real hard but firm and it'll work. So I take the phone with me go out with my screwdriver and give it 2 raps put the key in so I can tell him he's full of B.S. and it turns. Just like that it works, I cycle it numerous times and it's fine. He says there's a pin in there that gets stuck some times. I don't know about that but hey it did work. So if you all ever get your ignition switch stuck 2 raps with a screw driver will do it. You know I almost wish it hadn't worked; so now I owe some beers and will gladly pay them if only I don't have to hear about it for the next 6 months.
