Got a whole turn out of my head pipe bolt.
Did some routine check up on the '05 RK.
Checked all nuts / bolts / cables.
One headbolt that attaches the exhaust pipe to the head took almost a whole turn. I used an open end wrench and gave it a good tight fit.
Here comes a really dumb question.......
Should there be any play in the bolt to allow for expansion when the bike is hot?
That sucker is pretty tight now.
Thanks
Thanks
RE: Got a whole turn out of my head pipe bolt.
what pipes do you have? i replaced my nuts with the steel locking ones and washers. dont use nylon locking nuts, they will get too hot. mine have been tight since day one after installing the locking nuts. i had to tighten the stockers about once a week.
Did you use a torque wrench to tighten it up? How tight is one turn?
On my RK there is one nut that there's no way to get a torque wrench on it, 12 point box end only. Last week I installed a set of V&H Dresser Duals and discovered my exhaust flange bolts were very loose. The bracket for the rear pipe that bolts to the top of the transmission was also broken, had to get a replacement. I did my own service at 10K miles and I'm positive I checked all the exhaust fasteners.
ORIGINAL: Anthony8858
Thanks
Thanks
