Got a whole turn out of my head pipe bolt.
Old 08-11-2006, 05:12 PM
dawg's Avatar
dawg
dawg is offline
Received 3,244 Likes on 1,851 Posts
Default RE: Got a whole turn out of my head pipe bolt.
ORIGINAL: BIGSKY_FLHXI
Okay, so a little off topic......You guess with the V&H Dresser duals...How do you like them? I am thinking about getting them and using my SE slip ons.
Love 'em. Using them with V&H classic straight cuts with bullet end caps. Sound is great, ride is great.
Old 08-11-2006, 05:52 PM
Neckball's Avatar
Neckball
Neckball is offline
Fit and finish of my Dresser Duals is A+. I don't know if there's any difference in the power, I really haven't gotten on it too hard yet. It does seem to rev quicker, though. No noticeable torque loss like I was hearing about but that's only what the butt dyno tells me. You can really notice the absence of the heat from the right side. However, my SEII's got louder than I want, the tone even changed. I'm researching what slip-ons to change to. I need to spend some time at the dealer's hanging around to listen to some bikes with different muffs before I make a change.
Old 08-11-2006, 06:07 PM
Anthony8858's Avatar
Anthony8858
Anthony8858 is offline
ORIGINAL: Neckball
Did you use a torque wrench to tighten it up? How tight is one turn?
NO I did not use a torque wrench.
And yes, it's very tight. Now I'm concerned that they're too tight.
Is that possible? If I possibly over-tightened them, but didn't break anything, is that still OK?
Old 08-11-2006, 06:18 PM
dawg's Avatar
dawg
dawg is offline
ORIGINAL: Anthony8858
ORIGINAL: Neckball
I posted above about V&H saying just to snug them until tight. I couldn't get a good fit on the wrench on the rear flange nuts so I know that those are just snug and not overtightened. The ones one the front are fairly tight. I am just going to check them every so often and not worry about it.
Old 08-11-2006, 06:48 PM
04RoadKing's Avatar
04RoadKing
04RoadKing is offline
Use a 1/4" drive socket with a torque wrench, and torque to spec's in the service manual. I don't remember off the top of my head what the specs our,Sorry. If you can't get the 1/4" drive socket to fit you may need to losen up the heat shield and slide it out of the way. That's what I had to do on my 2-1 Thunderheader. If you torque it down to the correct spec you should never have to worry about them again.
Old 08-11-2006, 11:11 PM
valvestem's Avatar
valvestem
valvestem is offline
The flange will usually distort if the exhaust bolts are overtightened. I learned the hard way on a Softail. It was not fun trying to get the exhaust off after that, but it did come off with some persuasion.
ORIGINAL: Neckball
Old 08-12-2006, 12:20 AM
Anthony8858
OK, thanks.
So I guess I should ask whether or not I should back them off a bit?
Should I?
paco12
08-17-2019 10:41 AM
sincitychoppa
04-26-2015 08:29 PM
Crimson
Exhaust System Topics
09-05-2014 03:47 PM
SBJJC
04-02-2012 04:16 PM
OceanState401
11-03-2009 09:23 PM
Quick Reply: Got a whole turn out of my head pipe bolt.
